Bad Idler Pulley
Old Nov 6, 2005 | 04:11 PM
SFB767's Avatar
Question Bad Idler Pulley
When my car is idling it sounds like there's a bunch of canaries under my hood and sometimes when I turn it off, it makes a very quick squeal/sqweak before the engine shuts off.
Is my idler pulley going bad or does it just need a shot of WD-40?
Which pulley on the engine's bracketry is it?
Old Nov 8, 2005 | 02:45 AM
mook99TA's Avatar
Re: Bad Idler Pulley
when looking at your engine its the pulley on the top left when standing infront of your car looking into the engine compartment. Its not conected to anything eg(alternator or water pump). I have the same problem just can't find one anywhere besides the dealer and they want to much money for it. Let me know if you find one somewhere cheap
Old Nov 8, 2005 | 12:34 PM
mark896's Avatar
It's either the serpentine belt tensioner (the one described as above) or the belt itself (not likely). In my case, it was actually the a/c tensioner pulley (only made the noise when a/c was on).
Old Nov 8, 2005 | 01:10 PM
teke184's Avatar
WD-40 is a solvent more than it is an oil.
it will actually dissolve the lubricants in the bearings, evaporate out and leave everything in worse shape.
seems like i've heard the pulleys are $50 or so bucks...watch ebay
Old Nov 8, 2005 | 07:05 PM
SFB767's Avatar
So it's the one that moves a little and the same one that automatically tensions your new serpentine belt? How do you get the thing to come off and DEFINITELY determine that that's the problem pulley? When I have my hood open, everything seems fine, it's when I'm idling when it makes noise. As soon as I hit the gas it disappears.
Old Nov 9, 2005 | 04:03 AM
mark896's Avatar
Then just idle the car and pop the hood!
I actually used a car stethoscope. I can almost guarantee you it's your serpentine belt tensioner pulley (the one nearest your throttle body). I think the 99's particularly had a problem with these.
HectorM52
Jul 30, 2017 11:46 AM
BLK1997Z28
May 7, 2015 03:01 PM
