low rpm misfire/bad gas mileage. no code?
Lately I've been having a low rpm misfire, the engine doesnt run as smooth as it did (it never really ran THAT smooth...) and if its in 5th or sixt, if i give it 3/4 or full throttle it backfires a little. Also my gas mileage has dropped to about 16 city/25 highway, it was 21 city or so before and at least 30 on the highway. I took it to autozone to get the codes scanned and there was nothing stored. From searching I figured it was the 02s (its just about to hit 80,000 miles) but there was no code, do they go bad without setting a code? Or could it be something else? I did pull the front driverside spark plug to take a look at it, maybe I didnt get it back on all the way or something. its an m6 2000 Z28. Thanks!
Re: low rpm misfire/bad gas mileage. no code?
Originally Posted by blown94
low rpm misfire? while under load or at idle? makes a big difference. give more details.
edit: it also doesnt seem to do it as much (if at all) when the engine is cold then when it is hot. Thats why i suspected 02s
F'n1996Z28SS
Aug 23, 2023 11:19 PM
