what does it take to get 650hp?
Old Dec 19, 2005 | 08:04 PM
mike5685's Avatar
Just wondering, what does it take to get a 2000 SS into the 650 Hp range and how much it would cost?
thanks ---Mike
Old Dec 19, 2005 | 08:12 PM
Capn Pete's Avatar
Re: what does it take to get 650hp?
I'd say heads & cam and a ~200 shot of nitrous should do it. Cost? I dunno ... a couple grand?? To do it RIGHT though (in a manner that will last more than 1 or 2 good runs) it'll cost you a little more.
Old Dec 19, 2005 | 08:14 PM
myslowcamaro's Avatar
low compression lsx, aggressive cam, stage 2.5 or 3 heads, fi with about 16-18 psi, 42+lb injectors, tune, ls6 or fast 90 intake
Old Dec 20, 2005 | 12:21 AM
Need4Camaro's Avatar
I'm curious, would it be possible to obtain that kind of power without any type of poweradder? (Turbo, SC, N20) While keeping it fairly streetable?
Old Dec 20, 2005 | 01:07 AM
Mike94ZLT1's Avatar
Sure, it could be done without a power adder. Stock displacement, no way. You would need a large stroker, some AMAZING heads, a large solid roller cam, and a beefy bottom end. Realistically though, i doubt it would be very streetable.
Old Dec 20, 2005 | 05:29 AM
TheMT1's Avatar
http://fbodycentral.com/forum/showth...threadid=24481
Old Dec 20, 2005 | 10:28 AM
Capn Pete's Avatar
^ ^ ^ Holy Horsepower Batman!!! ^ ^ ^ None of the specs seem like anything way out there either?! Crazy!
Old Dec 20, 2005 | 01:08 PM
TheMT1's Avatar
I've been drooling over LS2 blocks ever since.
Here's another thread . . .
http://www.ls1tech.com/forums/showthread.php?t=309920
Track results . . .
http://www.ls1tech.com/forums/showthread.php?t=411880
600rwhp discussion . . .
http://www.ls1tech.com/forums/showthread.php?t=380543
Old Dec 20, 2005 | 03:20 PM
Victory Racing's Avatar
It is certainly possible to hit 650hp at the flywheel N/A in an LS1.
Our 408's routinely make over 625hp with good heads and a FAST 90/90 set-up.
Old Dec 20, 2005 | 05:26 PM
what cam specs you use on them nick? also is that a stroker?
Old Dec 21, 2005 | 12:10 AM
billyburnout's Avatar
If you use a lot of juice for your power ou can maintain quite a bit of streetablility.
Old Dec 21, 2005 | 04:16 AM
Cam specs aren't something we advertise, no offense taken I hope.
That is a 408 iron, so its 4.030 bore x 4.000 stroke
Old Dec 21, 2005 | 06:45 PM
no offense taken. just when i buy one, you will give me the info? or do a tsp?
Old Dec 21, 2005 | 07:03 PM
Customers get full build sheets and specs for every part they order, cam specs included.
Old Dec 22, 2005 | 08:08 AM
Cobra Killer's Avatar
So why hide it? How about some links to dyno sheets showing the results?
