belts?
Old Oct 12, 2005 | 07:42 PM
MarlboroMan's Avatar
belts?
hey guys, i know i read about this in some other topic a while ago but i cant find that topic again now that i actually need it. Ok heres the deal, when i turn on my car and at low rpms it squeels real bad. is it my belts?? just gettin yalls ideas so someone doesnt bs me around.. thanks.
Old Oct 12, 2005 | 08:24 PM
Zitty'sZ's Avatar
Re: belts?
That sounds like your problem.You can spray a little belt dressing on your belts while the engine is idling, if this quiets it down then thats your problem.If you don't have belt dressing you can substitute it with wd-40 or something similar, but don't go overboard with it. If it quiets down for just a little while and then starts to squeal again, replace your belts.
Old Oct 14, 2005 | 03:14 PM
ibyourhucklebery's Avatar
Re: belts?
wd-40??? belt dressing... yea that will do it, if you want to @ss it all up. TRUST ME!!!, just replace the freaking belts. It's not hard. You will spent more time cussing @ the fact black dressing will be all over the engine and hood than just replacing the belts.
Old Oct 14, 2005 | 07:06 PM
Zitty'sZ's Avatar
Re: belts?
I guess someone does not understand what a LITTLE means.Since when did belt dressing start hurting vehicles?The advice that was given was not only a diagnostic tool to see if that is his problem,but MAYBE, JUST MAYBE, it would also solve his problem! Before you can fix a problem, you have to know what is causing it, you don't just start changing out parts hoping you will fix it.I guess some people just do not understand common sense.
Old Oct 15, 2005 | 09:08 AM
Re: belts?
allright. If you read the instructions they do say to apply it on the belts and let dry. You are suppose to remove the belts and apply even if it is a "little". If you do apply it on the engine while running you will get crap all over the engine and hood (it sprays you know). Oh by the way...I have done this and it sucks. So go ahead do as you want. I guess common sense is a relative term.
95blkss
Sep 22, 2015 03:18 PM
rideordie
Sep 7, 2015 08:22 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
