Cold Starting Problems.... need HELP asap!!!
Old Dec 6, 2005 | 09:23 PM
IgorT.455/406's Avatar
Hey guys. I need help with my cousin's '98 Z28.
When it gets cold here (a few deg. below zero), her car starts, but revs upto 3000-4000 RPM, then down, then up again, then down to ROUGH idle (too low), then dies.
It sets no codes. When its warm, it runs OK, but, she says the milage is down.
I am thinking possibly TPS sensor. What do you guys think? Any way for me to check it (like unplugging it)?..
Thanks.
Old Dec 7, 2005 | 12:12 PM
NEWBIE T/A's Avatar
Lightbulb Guesses.
Perhaps there is a vaccuum leak or air leak somewhere ?
Have you looked at that little hole that is in the butterfly in the throttle body ?
Sometimes that will get plugged up and cause weird troubles.
I have no clue how to test a TPS, but would assume that if it was bad there would be a code somewhere .
Good Luck !
Britt
Old Dec 8, 2005 | 03:28 PM
NEWBIE T/A's Avatar
Cool How Ironic - just dealt w/ the same symptoms !
At least in regards to the start up, then die.
This was on a '99 (?) Ford 1/2 ton - we tapped on the IAC/TPS ( gently ) while the owner held the gas to keep it running. he said as I tapped on it, he could feel something come loose , and now it acts fine.
Probably a little pice of trash on the IAC.
Here's a pic of what I am referring to :
Entire article is here:
http://www.installuniversity.com/ins...ar/tb_swap.htm
May be of some help.
Britt
Old Dec 8, 2005 | 03:31 PM
PAGregSS's Avatar
Re: Cold Starting Problems.... need HELP asap!!!
Get some electric parts cleaner and spray the MAF and the IAC. Make sure it's just the cleaner and not a lube too. You want something that doesn't leave any residue. You can find it at just about any auto parts store.
94Form
Feb 10, 2015 11:23 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Brake_L8
Jan 20, 2015 09:44 AM
Britbilly
Jan 7, 2015 08:49 PM
