O2 sensor question
O2 sensor question
I just got a 02 Z28 6 speed and 2 days after my check engine light came on i checked it out and on the OBD2 scaner came up with catalest below thershhold bank 1 what do you guys think??? is it the O2 sensor?
Re: O2 sensor question
It sounds like the O2 sensor after the catalyst (or lack thereof). Check connections first. It could actually be the converter itself but less likely.
Regards
Before calling it a bad cat, I'd check the sensor. Switch the sensors behind the cats. If the problem stays on the same side, it's most likely the cat (but could be the connection). If the problem follows the sensor over to the other side, then it's most likely the sensor.
try hitting the cat you think is bad with a rubber mallet, if it rattles it's junk if not then it's possible it's still good. Now don't think if it doesn't rattle that it's not bad either, and don't smash it, just hit it kinda lightly.
