Anybody running a Cheatr or Old man cam?
Just wanted to know if you guys are happy or want more cam?
Debating about swapping cams for something stock sounding down the road. I'll be using stock manifolds but might be swapping over to an LS6 intake and possibly a catback.
Re: Anybody running a Cheatr or Old man cam?
Originally Posted by StudyTime
I'm sure you've read about Jason99TA's car. Have you?
Ben T.
Ben T.
or is that TILL u get the $$$ for headers?? If your worried bout loosing some TQ No.s w/long tubes just put shorites or mid-lengths on her man! Other wise it seems as though you robbing urself of Ponies and some Lbs...Just my $.02 tho
Originally Posted by CamaroRob97
Stock manifolds w/ a cam swap????
Originally Posted by Capn Pete
Another sleeper cam: LS6 cam
('02-'04 405HP version) ... apparently "cheap" compared to most other aftermarket cams too
I test drove a Z06 about a year ago, and when I fired it up, it didn't seem to idle any/much lumpier than my Z28. I could hear a little different tone while sitting inside the car, but you gotta figure, the 'Vette uses a completely different exhaust system than F-bodies, so a different sound doesn't mean it's because of the cam. Basically, as far as I'm concerned, the idle of the Z06 sounded like a smooth "stock" idle to me, and any difference with a cam in your Z28 could be easily blamed on a cat-back exhaust or something
(and not because of the cam).
How is the idle on it? I'm looking for completely stock idle. I read on LS1 tech that with the Cheatr cam you can still tell the car is cammed if you know your cars.
For all practicalities, I'd say it's a stock idle. If you get one, and you're not happy with the idle quality. Just have your idle raised, and then it will certainly smooth out.
OH, and when I heard Jason's car it was a cold start and still sounded how I described. Jason = Jason99ta
Ben T.
The LS6 is a stock GM cam and idles well.....stock.
The GT2-3 idles stock as well and is an LS6 on steroids.
The CheaTR would be the LS6 roid raging. Said to idle 98% stock-haven't heard one, but a bad plug can make and engine a little rough too. I'm sure the tune makes a world of difference.
The stealth cams are described as having a "nervous" idle.
lump my lump my lump my lump....my lovely engine lump...
sorry...i'm still drunk i think
but yeah....i understand the whole "sleeper" thing...but GAWD...the lope of a nasty cam, on the verge of stalling....sounds
