K&N: Track Only
Old Oct 20, 2005 | 07:15 PM
SFB767's Avatar
Question K&N: Track Only
I prefer to use a Fram paper filter for daily driving, but how effective would a dry (ungreased) K&N filter be for use ONLY at the track?
Would it make any difference at all over the Fram paper filter or would it be too small (if even existent) to notice? Also, would just pulling my current filter out for a pass be better than the K&N?
Old Oct 20, 2005 | 07:25 PM
99blackSS's Avatar
Re: K&N: Track Only
Of course pulling out your filter would flow better then a K&N.
IDK the gains between greased and ungreased K&N.
Old Oct 20, 2005 | 10:55 PM
Black6spdZ's Avatar
Re: K&N: Track Only
i highly doubt you will notice the diff. if you arent going to oil the K&N then you might as well not run a filter because the oil is what catches all of the dust. Not having oil on their is not going to affect the flow capabilities by much if anything at all.
my $.02
Scott
Old Oct 21, 2005 | 07:12 AM
TheMT1's Avatar
Re: K&N: Track Only
Wasn't there a test of all the air filters that showed a stock GM air filter getting the most horsepower. I remember something like 2hp more than no filter at all?
Old Oct 21, 2005 | 10:08 AM
Greed4Speed's Avatar
Re: K&N: Track Only
Hp on a dyno doesn't always equate to better track times. I've seen 1 comparison, not enough for any concrete conclusion.
If you're running and un-OILED (yes they're oiled not greased) K&N you might as well be running no filter.
Old Oct 22, 2005 | 02:45 PM
psychocabbage's Avatar
Re: K&N: Track Only
I tested it over 20 times on 2 different days.. 3rwhp difference in my tests.. enough for me to say run the AC Delco filter and be happy..
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
