**Which** is better
Old Oct 17, 2005 | 07:04 PM
6shot38's Avatar
**Which** is better
ls2 intake or ls6
Old Oct 17, 2005 | 10:18 PM
Keliente@pcmforless's Avatar
Re: witch is better
your answer
LS6
Old Oct 17, 2005 | 10:35 PM
Shempy's Avatar
Re: witch is better
Are you asking which witch is the good witch and which witch is the bad witch?
Old Oct 17, 2005 | 10:36 PM
LJ93Z28GM's Avatar
Re: witch is better
Halloween is coming. Witch out.
LS6
Old Oct 17, 2005 | 11:21 PM
Beast96Z's Avatar
Re: witch is better
The LS2 intake sucks. The LS6 is a clear winner.
Old Oct 18, 2005 | 08:22 AM
ss_slayer's Avatar
Re: witch is better
Ls6
Old Oct 18, 2005 | 09:16 AM
teke184's Avatar
Re: witch is better
for most bolt on or cammed engines...even some strokers...LS6
bigger ci engines or FI...the FAST will do a good job
someone tested the LS2 on a decent hp ls1...and lost 10 or so hp. go figure...i guess it's just TOO big
Old Oct 18, 2005 | 09:42 AM
Greed4Speed's Avatar
Re: witch is better
bad witches are better....
Old Oct 18, 2005 | 11:09 AM
Bert02SS
Guest
Posts: n/a
Re: witch is better
True, but the LS6 sucks WAY better.
Old Oct 18, 2005 | 01:59 PM
Re: witch is better
Sucks w/more velocity.
Old Oct 18, 2005 | 02:34 PM
javaradd's Avatar
Re: **Which** is better
If I had to do it again I would have done the FAST 90MM set-up, instead of getting the LS6 manifold. If you plan on doing heads/cam in the future get the FAST 90mm.
Old Oct 18, 2005 | 04:59 PM
Beast96Z's Avatar
Re: witch is better
It's not that, it just sucks. It's a poor design from the get go. That's why I'm wondering how the LS7 intake is gunna do. Everyone hyped up about the LS2 before it came out, only to be sadly dissappointed, now there doing the same with the LS7 intake. I guess we'll see when a few people get the LS7 heads/intake ordered. I know a guy or 2 on LS1tech have recieved there's, so we'll see.
Old Oct 18, 2005 | 08:35 PM
Plague's Avatar
ever think they ls2 intake maybe replaced later? kinda like the ls6 intake was put on ls1's? Maybe GM engineered one that was not as good to make something better later. Just the conspiracy theory in me.
