clutch install
Old Mar 19, 2005 | 07:08 PM
SpeedDemon02SS's Avatar
clutch install
how long does it take to install a clutch. i have to have it done (no access to a lift) what can i expect to spend? is it a hard job?
Old Mar 22, 2005 | 10:59 PM
toadies101's Avatar
Re: clutch install
You can do it on jack stands, I have done a z28 and a TA both took about 2-3 hours if you have everything there. I like to thoroughly inspect things though so it might take less time. Be sure to get your flywheel resurfaced!
Old Mar 23, 2005 | 04:14 PM
J's ss's Avatar
Re: clutch install
Im right in the middle of the install and trying top drop the trans.. there is this drivers side bolt that is giving me hell ,, cauz its right on the fire wall rachet wont work .. wrench wont work ... getting kinda despart..
Old Mar 23, 2005 | 04:16 PM
BlkLT1Z28's Avatar
Re: clutch install
I had my tranny droped in 45min and that was while F'ing with the long clutch fork bolt before I found out you could just pull it back. Its not hard, do it yourself. You will save some money.
Nov 18, 2023 07:21 PM
BPS
9
Mar 5, 2015 10:51 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
