WHat kind of gears
Re: WHat kind of gears
I'm ordering Motive 4.10 gears in about a week. I don't think you can really go wrong if you stay with known gear companys. I had Richmond 3.73's in my car for about a year and didn't have a problem with them. They whined but when I took that rear end out to sell to my friend, we readjusted them and they make no noise now. Good luck on your search for some gears.
i have the motives.. and they are the best thing i have gotten for my car, performance wise.... they should have been installed from the factory!! no whine, i got them from www.ls1speed.com you MUST ge the install kit!!!
You should also check if you have a series 2 or 3 carrier. I also have a 96 A4 with 2.73 gears, so I need a series 2 gears. You might be lucky and have 3.23 gears, so you can use the more popular series 3 gears. Makes a difference, b/c you'll almost never find used series 2 gears.
How do you know? Check your RPO codes on your driver side door. I think it's the "GU" series...that should say your gearing. Or look at your shifter. If the lowest selectable gear is "2" and then D and then OD, the you have series 2. If you have "1" and then "2" and then D...., you have series 3. But best to check the factor RPO codes to be sure.
Do this research before you buy your gears and have to return them.
im petty sure the sock gears in the 96-94 for A4 was 3.23.... mine was 3.42 in a M6..... the older A4 (93-95) were known to have 2.73's
search aroudn the forum for "1996 stock gear ratio"
F'n1996Z28SS
Aug 23, 2023 11:19 PM
