Rear End Girdle
Old Mar 4, 2005 | 10:53 PM
Bow94z's Avatar
Rear End Girdle
looking at the rear end girlde's and was wondering if it was just the back part of the pumpkin or does it cover it all around...i searched around and most people recommend it when installing gears on a stock 10 bolt, but im just wondering why they are soo expensive if its just the rear piece???
WHere do the middle studs bolt into?
how do they really hold the gears up better?
Old Mar 4, 2005 | 11:32 PM
blackztpi's Avatar
Re: Rear End Girdle
its a direct replacement for the stock rear end cover. I'd recomend getting one for the 10 bolt. helps give you a little reassurance for any unintended (or intended) hard launches. well, i'd buy the optional stud kit for the caps ikn the rear end. studs are stronger than bolts, u get the point. the bolts on the cover just sit against those studs or bolts (whichever one u end up having) and keep them from backing out or flexing out. lol, I'm not sure how to explain it, but it holds stuff in the same spot. the bolts the cover only tighten to 5 ft.lbs or so. i'm sure someone has a better explanation.
Old Mar 5, 2005 | 08:57 AM
Loadre's Avatar
Re: Rear End Girdle
Keeps the case from flexing, thus keeping the gears still.
Old Mar 5, 2005 | 06:35 PM
Bow94z's Avatar
Re: Rear End Girdle
Understood! just seems soo expensive for a rear end cover.
Well at least thunder racing has a good deal on motive 4:10's,Girlde w/ studs, gear oil and gm posi additive, and a deluxe insatll kit with wheel bearings and seals for 430$ which isnt too bad in my mind
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
