A4 and T56 Crossmember similar?
Hello,
I am in the process of chasing down a T56 to replace my shot A4. I was told that I can get away with using my A4 cross member, but I need to slot one of the holes to make it work. Any truth to that??
Also is the clutch pedal assembly the same from 93-02 the same? I found a set on Ebay and want to be sure before bidding on it.
Daryll
Daryll
Re: A4 and T56 Crossmember similar?
Nope crossmember's are different, just pick up a used one or get one from your local GM dealer. I did and it was only $40..
As for the pedeals yes they are all the same from 93-02.
Good luck on the swap, its fun.
NewsBot
Sep 30, 2015 04:20 PM
