rear end question
Old Mar 22, 2005 | 07:01 AM
badasschevy625's Avatar
rear end question
does anybody know where the wheel speed sensors are on a 95 and up camaro rear end and also mabye have a pic of them just wondering becuase i have a 94 rear end i want to put in mine but i need to figure out if this is oging to be a serious issue
Old Mar 22, 2005 | 07:05 AM
Dave89IROC's Avatar
Re: rear end question
if it had traction control(4channel ABS), it has one behind each wheel, it it is out of a ABS, non traction control car(3 channel ABS) it has one in the top of the differential
Old Mar 22, 2005 | 08:18 AM
CreatiVe2's Avatar
Heres a picture... but the rear on the right is destroyed.. you can still see the ABS ring... http://img119.exs.cx/img119/6571/reardestruction8dc.jpg
Old Mar 22, 2005 | 02:45 PM
it has one on top however my cars a 96 with traction control so will this work in my application or am i ****ed?
Old Mar 22, 2005 | 05:19 PM
94formulabz's Avatar
All you need to do is pull your axles, swap your brake/abs brackets over, and put your axles in the *new* rear. Well, and put something in the whole on top of the pumpkin if he doesn't include that sensor.
-brent
Old Mar 22, 2005 | 10:31 PM
92RS305#2's Avatar
94form is right, if you switch over the backing plates to the new rear end then you should have no probs. and just plug up the sensor hole on the new rear end.
Old Mar 23, 2005 | 07:15 PM
thanks alot but i dont got to worry bout plugging it cause the sensors there so ill just switch over all my brake **** and ill be cool
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
