limited slip to posi
Old Mar 9, 2005 | 03:05 AM
rhino38's Avatar
can you convert a limited slip to a posi rear end on a 78 z 28?
Old Mar 9, 2005 | 04:24 AM
rskrause's Avatar
Moderator
Re: limited slip to posi
"Positraction" is just a name GM uses (or maybe used in past and not currently?) to describe a limited slip differential. There are a variety of units available for most rear ends. Randy's Ring and Pinion is a good source of parts and info for rear ends.
Rich
Old Mar 9, 2005 | 07:04 AM
87DJP2001's Avatar
As stated in the above Post a Limited Slip and the shorten Name Posi (AKA Positraction GM's trade name) are ONE AND THE SAME.
Old Mar 9, 2005 | 11:32 AM
rhino38's Avatar
on my car when you get on it only 1 tire spins,and it doesnt get much traction.
Old Mar 9, 2005 | 11:48 AM
Then either the clutches in the limited slip unit are burned up, or it isn't a limited slip rear.
Old Mar 9, 2005 | 11:59 AM
87DJP2001's Avatar
G80 is the RPO for the Limited Slip option.
IndyZman
Oct 22, 2015 02:17 PM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
