what's involved 94z moser 12 bolt setup?
Looking at one now. Any mods that need to be made to put this puppy in? Is it a job I can handle in the garage with a turnkey setup? Thanks!
mudkat
mudkat
Re: what's involved 94z moser 12 bolt setup?
You will probably need a shorter driveshaft, although i've heard of some using their stock lengths. I tried to get my stock length in there and it's too long. Check with Denny's driveshafts on the net and he'll set you up. Not much to it. No other mods needed really assuming you get the right size sway bar hardware with the rear end cause the axle tubes are bigger then the stock tubes. You can do it in the garage but 2 people is always nicer.
Ken R.
Ken R.
kev93z28
Aug 19, 2002 12:48 AM
