Ripper shifter install.
Old Mar 21, 2005 | 01:08 PM
Dark Angel's Avatar
I just installed a ripper shifter in my '01 Z28. I set the holes up like the stock shifter. I just seems like it sits farther back.. Is this normal?
Old Mar 21, 2005 | 08:44 PM
GreenDemon's Avatar
Re: Ripper shifter install.
I set mine up so it sits farther back, but it didn't seem like it changed very much. I don't think changing the bolt plates make that much of a difference. The shifter height and/or angle difference from stock might be throwing you off too.
Old Mar 21, 2005 | 08:53 PM
Dark Angel's Avatar
I had the factory hurst short throw with an LSS. But this thing in 1,3,5 the stick is straight up and in 2,4,6 it is almost touching the console. I have my elbow against the seat to get it into gear. It seems the whole stick needs to be bent forward about an in and an inch cut off it.
Old Mar 21, 2005 | 09:02 PM
GreenDemon's Avatar
Yeah it's angled farther back but I don't think mine sits much farther back though, the odd gears sit just past vertical and the even ones seem pretty close to what they were, since the throws are a lot shorter. I guess I'm kind of biased though, I'm tall so I like the shifter further back than most. It's nice to be able to lean a little farther back now and still be able to row the gears.
Old Mar 21, 2005 | 09:05 PM
Dark Angel's Avatar
I'm 6'2" I gues it's something I am not used to. I will cut it down and see if it helps anything.
blac94Z
Nov 4, 2015 01:59 PM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CARiD
Sep 7, 2015 08:21 AM
