Spec stage 2 installed!
After reading much about spec's chatter, I was very pleased when I fired up the beast, dropped it into gear, let out the clutch pedal and no chatter. I've put about 30 miles on it around town now and it only chattered a small amount on the second drive. Other than that, it drives not much different from stock as far as I can tell. I also added poly motor mounts and trans mount. A small amount of vibration over stock but not too bad.
Re: Spec stage 2 installed!
That's encouraging. I bought a SPEC stage 3 from someone on the board and I'm going to install it this summer, although there are quite a few people on here that are not satisfied with their spec product.
Besides the motor and trans mounts did you change anything else along with the clutch? And did you buy an aftermarket flywheel or have your stock one resurfaced?
I just installed my stage III on Monday, It chatters like a MF!
I have to keep the rpms up guite a bit to get into first and it not chatter.
It performs well out of first though
I have only put 80 miles on it hough so we will see.
Does anyone elses pedal shake after thier clutch install cause mine does?
did u install the clutch urself or did a shop do it ... how long did it take .. I just ordered one.. and gonna drop it in myself .. just curiouse to see if u had any tips to make the job easy .
From my understanding the stage II has ALOT less chatter than the stage III. If i had it to do over i would go stage II. My stage III was TERRIBLE at first, better now thats its well broken in, but still rough on hills and whatnot.
joe.
joe.
stockssn2o
May 25, 2015 08:54 AM
High HP TA
Sep 6, 2002 08:00 PM
