Rear end leak
Old Mar 10, 2005 | 06:22 PM
3.8LCamaro98's Avatar
Rear end leak
I was wondering what usually causes rear end leaks or is it a sign of the rear end going out. I was think probably a gasket or something or is it something worse then that.
Old Mar 10, 2005 | 09:33 PM
OBE1 95Z28's Avatar
Re: Rear end leak
I've found that the pinion seal (front of the rear where the yoke mounts to the pinion gear) is the major source of leaks.
Old Mar 10, 2005 | 10:16 PM
Bow94z's Avatar
Re: Rear end leak
CORRECT!
The stock 7.5" 10 bolt from chevy is the biggest piece of JUNK ever!!!
Old Mar 11, 2005 | 02:20 AM
Re: Rear end leak
Yeah the car im looking at has a leaking rear end and is leaking exactly wherer you stated above. I was wondering is there any way in fixing that problem and would it be pricey? BTW the rear end is on an 98 SS.
Old Mar 11, 2005 | 07:08 AM
87DJP2001's Avatar
Re: Rear end leak
Not that expensive of a fix.
Old Mar 11, 2005 | 08:49 AM
Re: Rear end leak
What is all needed/parts to fix the problem. I think when/or it i get it ill just do it myself and save myself the money.
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
