Hurst billet plus install ?
Old Mar 17, 2005 | 10:51 AM
hllywd's Avatar
I just swaped out the factory shifter with the Hurst billet plus. Everything went slick except when all was said and done when shifting into reverse, the shifter hits the console and is hard to get into reverse. Everything lined up perfect so I dont know what went wrong.
Any thoughts?
Old Mar 17, 2005 | 02:15 PM
camz383's Avatar
Re: Hurst billet plus install ?
might be a stupid answer, but are you sure you bolted it to the correct side?
Old Mar 17, 2005 | 02:43 PM
Z95m6's Avatar
Any thoughts?
Is your handle loose at all? I have a 97+ console and i have no problem with my hurst hitting the side. You must have something seriously wrong.
Old Mar 17, 2005 | 04:00 PM
camz383's Avatar
that too, make sure you put lock tight on the threads, its a must
Old Mar 18, 2005 | 12:53 PM
hllywd's Avatar
Well seeings as we are in the process of getting about 10" of snow, I thought Id go out in the garage and take everything apart down to the shifter again. Nothing else to do...
The shifter is offset on its plate so it only goes one way, so thats on there right. It does look like its about 1/4" taller than the factory shifter. With the lower console back in place and all holes lined up the shaft that the shifter stick, (straight chrome stick) attaches to hits the passenger side clip where the top console slides into when shifting into reverse. Boy thats a mouthful, I hope you all can picture that.
The shifter stick attaches to the serrated side, (drivers side) of that shaft. Thats not a problem.
It still goes into reverse but its real tight and even tighter when the leather boot is snapped in place.
I hope that paints a better picture for you.
Thanks again
Old Mar 18, 2005 | 09:54 PM
Z95m6's Avatar
i just checked mine and there is at least 1-1.5 inches between the shifter and the console when the car is in reverse. Remember i'm now running a 97+ console too so our setup should be the same.
Old Mar 20, 2005 | 11:30 AM
z71camaro's Avatar
I had the same problem on my formula. Turns out its just the ends of the bolts for the stick that hit it. Put some spacers on the bolts and it clears.
Before I did that I switched to a poly trans mount (Unrelated) and it made it worse yet.
Old Mar 20, 2005 | 12:22 PM
hllywd's Avatar
Well I went ahead and pulled the whole shifter out and put it side by side with the factory one. Other than the new one being a half size bigger, the only other thing that I noticed was the factory shaft has a bend towards the drivers side, whereas the new one is straight up and down. The shaft is what hits the clip on the lower console.
What are my chances of heating up hardened steel and putting a 1/2 inch bend in it?
I think the spacers will help...
Thanks all
Old Mar 20, 2005 | 05:41 PM
Z95m6's Avatar
Thanks all
I'm running the straight up stick too just like yours. No problems here. Your problem is something else.
Old Mar 20, 2005 | 05:59 PM
97z28/m6's Avatar
my B&M has washers so you can move it back or forth does yours?
Old Mar 29, 2005 | 03:49 PM
hllywd's Avatar
Just got the right shifter back from Hurst. Fit like a glove.
Thanks all.
Old Mar 29, 2005 | 04:08 PM
Z95m6's Avatar
Thanks all.
What kind of shifter did they send you?
Old Mar 29, 2005 | 05:03 PM
hllywd's Avatar
By the size of it I think it might have been for a truck.
It was a half size bigger than the factory and this one.
Dont know for sure though.
Cant wait to start hammering thru the gears...
Nov 18, 2023 07:21 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Z28-50
Parts Wanted
Feb 21, 2015 09:00 PM
