shifter rattles in 3rd gear
Old Mar 3, 2005 | 11:33 PM
rob_ss's Avatar
any of you M6 guys have a problem where your shifter rattles in 3rd gear under load?
My 98SS has always rattled a little in 3rd, but now with 60k it's become more pronounced especially around 1/2 throttle acceleration.
Is there a way to stop it or reduce it?
Old Mar 5, 2005 | 09:40 AM
rob_ss's Avatar
Re: shifter rattles in 3rd gear
anyone? Bueller? Bueller?
Old Mar 5, 2005 | 07:36 PM
Bow94z's Avatar
Stock shifter? maybe a trans mount?
Old Mar 6, 2005 | 10:19 AM
MysticTeal 95 V6's Avatar
How bad of a rattle is it? Mine does it slightly in all gears but most noticeable is in 3rd gear under acceleration. It didn't start doing this until the throwout bearing started to rattle on me a few months ago which is around the same time I developed a slight leak around the bellhousing. With it in Neutral... can you hear a slight "whirring" sort of sound coming from the shifter for a second or two after you shut it off?
I'm replacing the slave and throwout bearing when I swap out the clutch... hopefully it'll clear up all the problems at once.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BigWil
Mar 29, 2015 12:24 PM
tds1213
Nov 27, 2014 12:55 PM
