Shifter popping out of 3rd?!?
Old Mar 22, 2005 | 11:10 AM
guyomatic's Avatar
Got a Pro 5.0 shifter. Installed it correctly, was working fine for a couple of weeks. Now when I shift from second to third and take my hand of right away, she'll pop into neutral. Anyone experience this before?
Old Mar 22, 2005 | 07:36 PM
camaro325's Avatar
Re: Shifter popping out of 3rd?!?
I have a b&m shifter (bought the car with it already installed) sometimes when I shift into 3rd it will pop right back out real quik, but it only happens once in a while
Old Mar 22, 2005 | 09:41 PM
thesource2004's Avatar
The problem is not the shifter , the fork is bad for 3rd&4th gear .
Old Mar 23, 2005 | 12:01 PM
evo.end3R's Avatar
you may want to try adjusting the stops before gettting a new synchro. take off the shift boot and you can asjust the front one from there, if you dont have enough room youll have to pull off the console then. When i installed mine i had the stops too short, but if i held it in place it wouldnt pop out, and now i have no problems at all. If backing out the front stop does not end your problem, its your synchro...and mine was only poping out of 3rd too, not 1st and 5th also, and the stop was the problem..try that, and then if that isnt it, your looking at some expesive work..
Old Mar 23, 2005 | 01:39 PM
sniffin94's Avatar
I secind the shift for possibility, if you adjust the stops back a little and it still does it, then it is time for a tranny rebuild. I did the same thing, nut second gear
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
350350
14
Aug 11, 2015 12:03 PM
Boss002
Jul 24, 2015 10:47 AM
ducttape1975
Jul 10, 2015 06:29 PM
