Replacing Reverse Synchro...need help!
Old Feb 27, 2005 | 05:39 PM
InGodITrust's Avatar
Ok, I'm trying to replace my reversce synchro because it keeps jumping out of reverse. So far I have the extension housing off and the first snap ring for the speedo gear. My understanding is that I need to pull the metal speedo gear off, remove the second snap ring, then remove the roller bearing along with the snap ring and spacer that are in front of it (towards back of car). Then I need to pull off the reverse gear. After that the reverse shift fork and synchro assembly. I was told all I need to do is turn the synchro around and reinstall it. Do I have to disassemble the synchro or do I just turn the whole assembly around and reinstall?
One more question....when I took my shifter out, I noticed that the cup in rear offset lever was loose. Is this a problem?
Any tips or advice is greatly appreciated
Old Feb 28, 2005 | 12:06 PM
Re: Replacing Reverse Synchro...need help!
...can anyone help me??
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
alex5366
Apr 1, 2015 09:27 AM
kizz
Aug 28, 2002 09:39 PM
