transmission question
Old Aug 15, 2006 | 11:02 PM
RKPsk8er's Avatar
I'm new here and I do a lot of reading around through threads, and I came across something about a skip shift eliminator or something of that nature? What does this mod actually do? how much would it cost? and what are the advantages of doing it?
thanks in advance
Ryan
Old Aug 16, 2006 | 07:56 AM
Capn Pete's Avatar
Re: transmission question
If you have a 6-speed, they have "skip shift" (or CAGS - Computer Assisted Gear Selection). What that does is force you into 4th gear from 1st if you're driving slow off the line (unless you accelerate quickly, then it won't activate). It's there to improve fuel economy. The Skip Shift Eliminator is just a little 2k ohm resistor that plugs into the wiring harness and gives the computer a signal saying you're accelerating quick. I think they cost around ~$25 - $30, and don't take long to install. Well worth the money and hassle IMO! I wouldn't want the computer telling me when/how to shift!
Old Aug 17, 2006 | 11:44 PM
RKPsk8er's Avatar
hmm...I dont understand how the computer could control your shifts on a manual transmission.
Old Aug 18, 2006 | 12:43 AM
angel71rs's Avatar
It doesn't control the shifts, it engages a solenoid that interferes with your ability to shift from 1st to 2nd under light throttle. Shifter feels like it hits a stop, so you have to slide it over to 4th. Car nearly bogs down turning such low rpm in 4th, but it helps with mileage. Annoying as hell.
1st thing that should be done on an M6 equipped fbod.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Newgmman
Feb 25, 2015 02:53 PM
Lonemechanic
Feb 19, 2015 10:29 AM
cmdeshon
Jan 4, 2015 11:15 AM
Kyle@CSS
Sep 14, 2002 04:06 PM
