Transmission speedo differences
Old Aug 2, 2006 | 09:46 AM
Old Chevy Lover's Avatar
What is the difference in 4L60E trannys where one has the speedo hookup on the drivers side (bigger connecter) and the other has the speedo hookup on the passengers side (smaller connecter)?
Old Aug 2, 2006 | 12:01 PM
12SCNDZ's Avatar
Re: Transmission speedo differences
Just a GM design change. The exciter ring on the output shaft is identical on both. You can swap tail housing and speedo assemblies from one to another...As long as you have the correct housing/speedo for the vehicle. Also remember this only applies to pre '98 units. In '98 GM went to the 2 piece case, which has a 6 bolt tail housing.
Frank
CPT
Old Aug 2, 2006 | 11:23 PM
Is it possible to just swap electrical connectors, or is the actual wiring different?
warmeck
Aug 24, 2024 08:05 PM
mschmidt33
Mar 15, 2015 07:20 PM
blac94Z
Feb 10, 2015 11:02 AM
Jul 4, 2005 05:00 PM
