stock tranny in 1998 z28 A4 is called??
Re: stock tranny in 1998 z28 A4 is called??
The tranny you have is the 4L60E. It's a descendent of the old TH350, which later gained 4th gear (overdrive) and was called the 700-R4, a.k.a., 4L60. The "E" was added to 4L60 when they went fully electronic in around ~93
As far as shift kits, Trans-go is a popular choice among many on this board, but B&M also makes a good kit (they actually offer 2 kits, 1 being the "shift improver" and 1 being the "trans-pak" ... the Trans-pak is the more complete kit).
Basically you can expect firmer, more crisp shifts with a kit (less slippage during the shift, which is good, because slip creates heat, and heat kills automatics
.As far as shift kits, Trans-go is a popular choice among many on this board, but B&M also makes a good kit (they actually offer 2 kits, 1 being the "shift improver" and 1 being the "trans-pak" ... the Trans-pak is the more complete kit).
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Nov 30, 2014 08:41 AM
