Help! Hole in transmission housing!
Old Aug 17, 2006 | 01:07 PM
Jeff Nichols's Avatar
Well, as the title says, my mechanic said he saw a hole in the transmission. I had been getting a vibration at certain RPMs and he said that something (but couldn't determine exactly what) must have come loose, put a hole in the tranmission casing, and now the torque converter is not spinning "true", causing the vibration.
I haven't had a chance to look myself yet, but I thought I would ask the collective wisdom of this forum about the best way to proceed.
If there is a hole in the transmission, and let's say it came from something inside, wouldn't I notice poor/bad/non-exsistant transmission behavior? The tranny shifts just fine; I really notice no difference in the transmission behavior itself.
My "crazy idea" (or crazy hope) is that something else (not in the tranny) let loose, so I can just JBWeld the hole, get a new torque converter and possibly input shaft and be on my way. That sounds so much better than paying a transmission shop several thousand dollars for a rebuilt tranny.
Any thoughts/hints/what-to-look-for ideas?
Thanks.
Jeff
Old Aug 17, 2006 | 02:02 PM
Blue96z28's Avatar
Re: Help! Hole in transmission housing!
I would think if you have vibration problems, then you have more problems then just the hole in the housing, its just a matter of time if the TC is spinning off axis then it will eat the front seal/bearings in no time. Where is the hole at? Pan? Casting?
Old Aug 17, 2006 | 02:17 PM
My understanding was the hole is in the casting, not the pan. I'm not losing any fluid so I am also assuming the hole is near the top.
I agree I have to stop driving it and just get under there and look for myself. It's just strange that the TC would be affected. The mechanic (and I do trust his work) couldn't find missing bolts or missing weights or anything from the TC or flywheel.
Jeff
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Injuneer
May 15, 2015 08:45 AM
Apr 16, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
CaRParts102
Dec 6, 2014 08:45 AM
