700R4, Lock-up or non locking.
Old Aug 14, 2006 | 12:57 PM
93yellowta's Avatar
My 700R4 went out in my 93 ta.. I am getting another tranny from a friend of mine in great shape with the billet servo and a tci shift kit. anyways he has a b&m holeshot 3000 non lockup stall in it, I thought I read somewhere that a non-lockup stall is a bad idea for a 700R4/4L60. is this true? I know mpg's will suffer alittle. but I do alot of highway driving. will I gain anything performance wise with the non-lockup over the lockup? I have the 306 cam so it likes to come on around 3500rpms anyways...thanks for the help>
Old Aug 14, 2006 | 06:45 PM
93yellowta's Avatar
Re: 700R4, Lock-up or non locking.
Nobody know's?
Old Aug 14, 2006 | 08:13 PM
12SCNDZ's Avatar
The reason many switch to non lock-up in a 700 (4L60) is because the lock-up clutches in high stall (small diameter) converters aren't very well known for holding up.
You will notice a decrease in fuel milage.
The transmission also HAS to be modified to use a non lock-up converter. You simply can't just throw a non lock-up in a lock-up transmission. Some things in the pump need to be modified to provide proper cooler flow. Without these mods, the trans and converter will overheat.
Frank
CPT
Old Aug 14, 2006 | 08:21 PM
93yellowta's Avatar
thanks..Frank
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
jimmybandana
Mar 22, 2015 07:44 PM
CaRParts102
Dec 6, 2014 08:45 AM
