rear end rebuild questions.
Old Aug 28, 2006 | 04:46 PM
transAMdriv3r's Avatar
first off the car is in my sig and it is all stock. since my posi is broken i need to drop the rear end and since it will be down ill put some gears in it. my questions to you are:
1. do i need to drop the rear for this project
2. how hard is it to drop the rear (never done this before)
3. what gears should i get
a. my car makes a lot of stops and goes in the city
b. some highway driving
c. i dont care about gas mileage
d. what brand of posi , ring and pinion would you buy
e. what else should i replace while im at it.
Old Aug 29, 2006 | 10:00 AM
Alvin@pcmforless.com's Avatar
Re: rear end rebuild questions.
http://www.keliente.com/gears.htm
Old Aug 29, 2006 | 02:14 PM
thanks alot. that will help plenty
Greg,
Old Aug 30, 2006 | 07:50 PM
matLT1's Avatar
For an A4 I'd recommend 3.73's. I am at about 1500 rpm around town and 3k on the expressway @ 78-80mph. I have richmonds and have always liked them, they whine a little but I like the sound. Eaton makes a descent posi unit too, I havn't had any personal experience but have heard good things.
Also, If you are going to have the rear apart, you might as well just get the Mega Installation kit. It will have all the parts you need to rebuild your rearend. Once you have installed these parts, the gears and posi it will be good as new...
Old Aug 31, 2006 | 03:07 PM
cool , thanks for the help. i cant wait to see this thing in action.
Old Aug 31, 2006 | 05:31 PM
Get the latest issue of High Performance Pontiac magazine. A good article on beefing up the stock 10bolt, with part #'s and prices. Just recognize that there is a limit to what you can do with it. At your current power level, you'll be fine. But if you are thinking about some serious HP upgrades in the future, you might want to think twice before you invest $1,000+ in rebuilding the 10-bolt. With that much money, you're almost 1/2-way to a 12-bolt.
Old Sep 1, 2006 | 09:50 AM
angel71rs's Avatar
no, I've done gear swaps on car and out... easier to do adjustments out of car.
not hard, even easier on coil spring cars vs leaf spring. Just be careful where you put stands under the body so you don't damage anything, especially brake lines. use a floor jack to lower... one man job, buddy helps tho... like to tell you to stop lowering when he spots the flex brake line that didn't get unhooked.
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
