I dont get it
Old Aug 29, 2006 | 03:45 PM
J's ss's Avatar
I dont get it
ive replaced my starter on my 01 ss twice now and getting the same result each time. The eye for the mounting bolt keeps breaking off of the starter. I know im installing the thing right. have put them on other vechicals with no problem. I do have a spec flywheel with a spec clutch. car has been drivin bout ten thousand miles after new clutch and flywheel were installed before any problem , I guess my question is could my fly weel be damaging the starter... car sounds normal on each start.. what gives
Old Aug 29, 2006 | 06:03 PM
davidarel's Avatar
Re: I dont get it
It sounds like the bolts are loosening over time and when you try to start it, the torque is weakening the mount. Try removing the bolts and cleaning the threads and bolts and then using some blue loctite.
Old Aug 29, 2006 | 09:43 PM
razor02097's Avatar
Re: I dont get it
#1 what kind of thread lock do you use
#2 are you shimming the starter out?
Old Aug 30, 2006 | 02:44 PM
J's ss's Avatar
Re: I dont get it
no shim there was none on my original but i will try the thread locker since i did not use it thanks
