TIme ran out on my 10 bolt but I have one question
Old Aug 19, 2006 | 02:17 PM
Getsome17's Avatar
Well after sitting behind the street twin for about 6 months now my rearend finally gave up, and a few of the teeth on the pinion gear broke off. I wont be able to afford a 12 bolt for another month or so which I have been saving for anyways my question is Is it worth fixing??
The summer is getting shorter by the day and If I fix it I will have it back on the road sooner but I am not sure how big of a job it is. Does the whole rearend have to come out to change the ring and pinion gear or can it be done in the car. I will have to get someone to set the gears up for me, but other then that I can do the rest myself.
http://fastcompany.ca/forum/showthread.php?t=1773
Old Aug 19, 2006 | 02:46 PM
Capn Pete's Avatar
Re: TIme ran out on my 10 bolt but I have one question
The gears can be done in the car (had to change them myself a couple months ago!). Support the frame on jack stands, and let the diff hang as low as it can so it's easier to access. For what a set of gears cost, I'd replace the ring & pinion for now (try to find some used off e-Bay or something) then get the 12-bolt once you've got the funds (and when you break the gears again!! )
Old Aug 19, 2006 | 05:59 PM
00cls1camaross's Avatar
just curious captain pete... did you get your name from cocunut pete from club dread?
Old Aug 19, 2006 | 08:29 PM
Capn Pete's Avatar
No sir. I've been carrying the nick-name "Cap'n Pete" since highschool!! Actually, it'll be 10 years this fall that I "earned" it!!
Old Aug 20, 2006 | 03:32 PM
Getsome17's Avatar
well I will probably pick up a set and get them installed untill I get the 12 bolt mabe nows a good time to try out some 4.10's
Noenav
Mar 1, 2019 07:38 AM
Feffman
Oct 9, 2015 05:42 AM
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
