trans seems to shift hard...could it be the rear end?
Old Aug 23, 2006 | 08:55 PM
terrible 1's Avatar
like the title says...i changed the the the EPC solenoid...the fluid is good and the mounts are good. could the gears have too much slop in them. i mean after all i do have DR's on a panzy axle.
Old Aug 24, 2006 | 09:57 AM
Sweetred95ta's Avatar
Re: trans seems to shift hard...could it be the rear end?
I don't think I've ever heard of a car shifting hard because the gears were loose. The transmission holds constant pressure on the gears, and even if they were loose, wouldn't lose slack on shifts. They would make a lot of noise if they were loose, also. What's an EPC? Electronic Pressure Control? If so, that could be the source of your snappier shifts.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
