What gear is it?
Old Aug 26, 2006 | 08:15 PM
shriekingtires's Avatar
What gear is it?
Does anybody know what size rearend was installed on '96 Z-28?? Or what the options were? What type of 1/4 improvement can I expect from from changing the gears on my basically stock car (just mufflers and KN)? What do you recommend for a car that will probably remain stock for, at least a few years? It has factory spec 245/50 Eagle GSC tires on 16 inch rims.
I've searched through the threads on this topic but couldn't find a clear answer. Help me out please. Thanks>!
Old Aug 26, 2006 | 09:33 PM
Keliente@pcmforless's Avatar
Re: What gear is it?
Size, as far as gear ratio? Check your RPO codes (door jamb or glovebox). GU2 = 2.73. GU5 = 3.23. GU6 = 3.42.
Gear change (to 3.73 for auto or 4.10 for manual) makes a big difference in the way the car feels...much more pep in your step. A '93 formula that I installed 3.73s in lost a half second in the eighth...my '00 Z28 that I put 4.10s in lost three tenths in the 1/8th. Good bang for the buck.
Old Aug 27, 2006 | 01:12 AM
NoRiceInside's Avatar
ive always wondered if 4.10s were too steep...but now that you put it as "4.10 for manual" i realize its because with double overdrive M6s can get away with it. i love learning ****
Old Aug 27, 2006 | 02:33 AM
Lees94Formula's Avatar
If you have an automatic and can select first with the shifter, you have 3.23's. If it only lets you select second, you have 2.73's. Manual transmissions came with 3.42's.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
