Shift
Old Jul 30, 2006 | 12:22 PM
ncarlson's Avatar
Shift
history< 94 5.7 a4 3.73 1.6 r.r. last yr upped line pressure car shifted frim raced at track 7- 10 xs no problems. now friday put 52mm tb on, it shifts early and soft< @wot shift 6000 now 5200?>wants wrong
Old Jul 30, 2006 | 02:36 PM
12SCNDZ's Avatar
Re: Shift
Your throttle position sensor voltage is probably low. This is common with many aftermarket throttle bodies. The TPS sensor tells the transmission when to shift in relation to throttle opening. It bolts to the side of your throttle body. You can check voltage with a scanner or a volt meter. You should have roughly .5V at idle, and approximately 4.5-5V at WOT.
Frank
CPT
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
