what would cause an extremly hard shift??
Old Aug 18, 2006 | 05:31 PM
terrible 1's Avatar
yeah...what the title says. mostly from 1st to 2nd but even from park to drive it blasts into gear.
Old Aug 18, 2006 | 06:11 PM
2001NBMZ28's Avatar
Re: what would cause an extremly hard shift??
Idle set too high - or increased line pressure cause of a code?
Old Aug 18, 2006 | 06:35 PM
terrible 1's Avatar
theres no code and it was rebuilt about a year ago...i dont beat on it at all.
Old Aug 18, 2006 | 11:51 PM
nodnarb481's Avatar
its probly the pressure in the lines are too high. check your epc solenoid. (i think its called epc it stands for electronic pressure control) Mine was dead and caused the pressure to be to high and resulted in the same symptoms.
Old Aug 19, 2006 | 09:04 AM
12SCNDZ's Avatar
A bad connection at the EPC solenoid, or a bad wire will cause high pressure. Max line pressure is part of "fail safe" for the 4L60E. When the EPC solenoid sees 0 voltage, it goes to max line pressure.
Frank
CPT
Old Aug 19, 2006 | 11:39 AM
terrible 1's Avatar
how can i check that?
Old Aug 20, 2006 | 10:54 AM
terrible 1's Avatar
which one is the EPC solenoid...i think i saw 2 on the bottom near the pan when i was takin it down last year.
Old Aug 20, 2006 | 11:09 AM
12SCNDZ's Avatar
The EPC solenoid is the large round one, on the passenger side of the valve body.
Frank
CPT
Old Aug 20, 2006 | 08:46 PM
terrible 1's Avatar
is there any way to check it or will it be one of thoes trial and error deals?
dylan1303
May 22, 2015 12:24 PM
96SilverRam
Apr 30, 2015 03:43 PM
jb4xx
Feb 2, 2015 10:00 PM
rjc1629
Jan 27, 2015 10:46 AM
Z28STYLE23
Aug 4, 2002 03:30 AM
