Noise from T56 after clutch swap
Old Aug 11, 2006 | 12:58 AM
race9's Avatar
I recently did a clutch/slp flywheel swap and now I have clunking in between gears at light to moderate acceleration. Seems fine under hard acceleration, shifting fast. I thought that it was the tranny mount until I got under the car and found play in the driveshaft. With the car in gear I can turn the driveshaft and hear the same clunking from the tranny so I know this problem is internal. All of the bolts are tight (the ones I could get to anyway). I used locktight on all of the flywheel and clutch bolts, so I don't think there is anything loose in there. My thoughts are that maybe the T.O. Bearing is the wrong size for the transmission spline (I didn't check this before I reinstalled everything) or the pilot bushing was the wrong diameter for the shaft (again, I didn't check before assembly). The part number for the clutch matched my application, but I can't help but wonder if something wrong ended up in the box. Thanks for any help!
Kevin
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
BigWil
Mar 29, 2015 12:24 PM
Briah.hood
Feb 17, 2015 02:10 PM
HectorM52
Jan 30, 2015 11:08 PM
