Pedal and Shifter Vibration. 3.8L
Test drove a 98 Camaro 3.8L V6 5spd 73K miles. Only thing i noticed was a slight vibration in the clutch pedal when partially depressed, and in the shifter when sitting in neutrel. While driving all was good.
Something to look into further or no?
Re: Pedal and Shifter Vibration. 3.8L
Nope....there usually will be some vibration felt with the pedal slightly depressed. I mean a little...very little. You should feel some vibrations in the shifter....so long as the engine is running. If anything, I would say tranny and/or motor mounts....but I wouldn't be overly concerned about it.
The pedal and shifter vibration wasnt real bad. It was the 1st time a drove manual transmission 4th gen, so I wasnt sure if it might even be normal.
CARiD
Sep 7, 2015 08:21 AM
