rear end leak- get new gasket or load it with sealant?
What is the best way to fix a leak from the rear end cover? Right now theres a crappy gasket and its got sealant on it but it is leaking. Doesn't look like the sealant was even all around though. What worked for you guys?
Re: rear end leak- get new gasket or load it with sealant?
Do not use just sealant; I tried that a couple times and it always leaked. Tried using just a gasket on the new car and it seems to be doing ok, although it's only been a few weeks. Of course I also torqued all the bolts to spec in a star pattern this time too, which might have something to do with it as well...
