So I am assuming this 10-bolt is bad? (vid, rear out of car)
Old Jul 29, 2006 | 02:08 AM
MustangEater82's Avatar
got it used, the axle shafts and pinion are out of the rear. The teeth look ok.
but well... you see what happens with I spin it. Maybe the pinion is bad?
http://videos.camaroz28.com/video/3b...0d00223d15.htm
Old Jul 29, 2006 | 07:51 AM
lt1srule's Avatar
Re: So I am assuming this 10-bolt is bad? (vid, rear out of car)
bad pinion bearing easy fix done mine in a few hours ...your will be quick seeing its out ..just get a new pinion race and bearing new seals and ues locktight and just preload it when you tighten it .feeling were it starts to want to bind wial tightening .you can use your old crush sleve .i did with no problems .just dont forget the locktight..and put a new pinion seal on it.piece of cake......
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
