rear end help??????
Old Aug 3, 2006 | 01:08 AM
slp97camaro's Avatar
Question rear end help??????
okay...so i decided to change my ring and pinion, because i blew 3 teeth off my last ring gear. i went with the precision gears 4.10 set in the stock 10 bolt. everything was going fine, until i started to put stuff back together. for some reason i cant line the holes up for the cross shaft or axle shaft. its like the spider gears locked up on me, and i cant move the thing to get the shaft threw. any ideas would be great, cuz i have no idea how to fix this
Old Aug 3, 2006 | 01:58 PM
Re: rear end help??????
i really need to get this fixed soon...so any ideas would be amazing..thanks
Old Aug 3, 2006 | 02:02 PM
OBE1 95Z28's Avatar
This link may be helpful:
http://www.geocities.com/MotorCity/Downs/4013/re.html
Old Aug 3, 2006 | 02:06 PM
no that did not help, but thanks alot for trying
im looking to realign the shaft that goes through the spider gears....and i believe its suppost to keep the axles from sliding in. i think its called something liek the cross-shaft, i took that out...and when everything was ready to go back in...the holes to put it in were all messed up and i cant get the pin in anymore
Old Aug 3, 2006 | 02:22 PM
anaik's Avatar
Do you have the Zexel-Torsen carrier? If so, this kit (#64002) is needed for the 4.10's.
http://www.slponline.com/view_product.asp?P=64045
Old Aug 3, 2006 | 02:33 PM
no...its the stock carrier
Old Aug 3, 2006 | 04:12 PM
http://i95.photobucket.com/albums/l1...5/103_0395.jpg
thats the hole that i was talking about...the spider gears inside wont move, and the thing is blocking the shaft from going through....any ideas?????
Old Aug 3, 2006 | 07:38 PM
it seems like the spider gears inside are bound up...and thats why im not able to move it, and align the holes....any ideas on how this would happen??
Old Aug 4, 2006 | 02:14 PM
ttt
Old Aug 4, 2006 | 02:31 PM
MyShibbyZ28's Avatar
FYI: You have a zexel torsen posi. You have an SS customized by SLP. Also, in the picture that definitely is not an auburn.
Why not try and stick a small screw driver in that hole and line it back up again. Otherwise take the posi out again, and try to fix it out in the open.
Old Aug 4, 2006 | 03:21 PM
alright...well all i know is it had a 4.10 in it before....ive tryed to pry the holes to line them up and nothing works, so i probably will take it apart
Old Aug 5, 2006 | 10:37 AM
mzgp5x's Avatar
A 410 ring has a larger tooth profile. A Zexel "square" section pin does not clear when engageing the carrier housing. SLP sells a split pin modification. Or, you can machine your own. I broke my 7 1/2. Pinion and Zexel diff case. Went with a Moser 12.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
