Shifter flex at WOT?
Old Apr 13, 2007 | 02:03 PM
BLKLT1's Avatar
Okay i just picked up a 98 m6 so i'm new to the whole m6 feel (not that i haven't driven standard before). At WOT it seems that the shifter will move slightly with the torque of the car, i can still shift fine, theres no slapping, grinding or signs that anything is wrong. Is this normal?
Old Apr 13, 2007 | 02:33 PM
Capn Pete's Avatar
Yeah, a bit of movement is normal. Figure you've got the torque arm bolted to the back of the tranny, so that's going to (attempt to) "lift" the back of the tranny when you really lay into the throttle. The only thing that will allow/prevent that movement is the tranny mount. Depending on the mileage on your car, maybe it's time to look at replacing the original mount? You "can" upgrade to a poly mount, but be forewarned that they are famous for causing (or making noticeable) extra vibrations in the drivetrain of your car, and they may become annoying to you. If you think the play/movement is too much, then just buy a NEW LS1 tranny mount, and be done with . If the shifter still moves the same, then I guess you accomplished nothing, but if it's a little better, then obviously the original mount was getting worn .
Old Apr 13, 2007 | 02:40 PM
97FormulaWS-6's Avatar
Yup, perfectly normal with a Manual tranny car for the shifter to move around as you drive the car.
Old Apr 13, 2007 | 07:16 PM
BLKLT1's Avatar
Niiice, i thought it was kinda cool, then wondered if something was F'ed. Now i just think its cool
Old Apr 13, 2007 | 08:36 PM
blackrat's Avatar
You can also get a tunnel mount for the torque arm. i have a poly mount and I still see a little flex, albeit less then before I did the swap.
blac94Z
Nov 4, 2015 01:59 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bxlt1
Sep 29, 2015 03:18 PM
CARiD
Sep 7, 2015 08:21 AM
