Peptobismal looking fluid?
i was driving and seen smoke, i knew it was fluid out of my a4 from the fluid lines, so i pull over and it was pink like pepto. So i know im going to need a rebuild im sure. Is that from the cooler inside of the radiator leaking and mixing? But my coolant is green and this was pretty pink. Also i just tossed in a new vig 3200, will that be reusable? what does this sound like to you trans experts thanks.
Sounds like water/coolant in the fluid. It's most likely because of a bad cooler in the radiator. As odd as it seems, you don't usually get trans fluid in the coolant.
Anytime a transmission gets water in it, it should be gone through. The water/coolant will break down the glue that holds the clutch material to the steel plates.
Sounds like you'll need a new radiator, too.
There's no real good way to get all the water/coolant out of the converter.
Frank
CPT
Frank
CPT
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
