Rear ends whining
Old Mar 18, 2007 | 11:59 AM
eagleknight97's Avatar
Rear ends whining
The rear end sounds like it whining to me so a few questions
How can I check to make sure it is the rear end and that something is wrong?
What does the whining actually mean has gone wrong with the rear?
How much time do i got?
Where can I get a rebuild kit for it?
How much would a shop charge?
Old Mar 18, 2007 | 01:20 PM
MyShibbyZ28's Avatar
gears typically whine after a while, especially aftermarket gears.
After the gears become worn they whine as they spin, its common.
Could be a day, could be never. Some people ignore the whine and are fine, others have their gears brake. Depends on how you drive the car. If it's never seen a track and is driven decent you are probably fine.
JEG'S, Summit, and other car part sellers have rebuild kits. When the gears whine, though, it's usually the gears and a rebuild kit won't help.
Around a couple hundred, without the part costs.
Getting new gears probably won't fix the whine unless they are stock sized gears. If you go with 3.73 or 4.10 there is a chance they will whine, usually depends on the brand.
Old Mar 18, 2007 | 11:58 PM
Its just the stock rear end with the stock 3.23's in it. The rear has 125k on it and the pinion seal was just done about 2 months ago, would that have anything to do with it?
Old Mar 19, 2007 | 11:11 AM
joe-96z1le's Avatar
I assume if the pinion seal was recently done that means the old seal was leaking. Chances are the oil level got too low and the pinion bearing might of been damaged. When my pinion bearing went out in my other car I went to the junkyard and picked up a used differential cheap. Not sure how loud the whine is but usually a pinion bearing going bad gets louder and the whine increases in pitch as speed increases.
Could also be an axle bearing but I'd go with pinion bearing.
Old Mar 19, 2007 | 11:48 AM
Yeah, it seems to get louder/more high pitched as speed increases.
I dont race or beat on my car, just use it for daily driver duties right now, so what would be a good course of action?
Old Mar 19, 2007 | 09:31 PM
matLT1's Avatar
My guess is when your seal was done the nut didn't get set correctly on the pinion flange. When you have this fixed IMO don't take it to the same place.
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
