TC choice advise.
Old Mar 20, 2007 | 10:40 PM
hey01's Avatar
Lightbulb TC choice advise.
ok i just read the sticky thread on TCs' and it cleared things up and confused me at the same time.
its time for a rebuild and im trying to choose my stall brand and speed.
since i only have a bolt on LT1 and i daily drive it i don't want to go above a 3000rpm.
Thoughts?
Old Mar 21, 2007 | 10:07 AM
Z-RATED94's Avatar
Thoughts?
What rearend gears (ratio) are in you car?
Old Mar 22, 2007 | 08:15 PM
hey01's Avatar
3.42
Old Mar 23, 2007 | 09:30 AM
Z-RATED94's Avatar
3.42
Then yes, with those gears, a "quality" 3k stall will be a nice addition to your set up.
Old Mar 24, 2007 | 02:49 PM
hey01's Avatar
great!
after reading all the sticky threads I was starting to think I shouldn't get one untill im modded up more.
Vigilante 9.5" Single Disk Lock-up Torque Converter, 200R4, 700R4/4L60E, 4L80E
2800 RPM picked out on thunder racing.
what is the diffrence with the single disk lock up and 3 disk lock up, besides $250
Old Mar 25, 2007 | 09:15 AM
Z-RATED94's Avatar
Lets just say, you don't need the 3 disk lockup, because your going to need that money for a set of drag radials. The Vig. is a nice choice, just don't forget to install a quality trans cooler also.
Old Mar 25, 2007 | 10:05 AM
hey01's Avatar
just do the usual "inline trans go 19400 GVW?"
Old Mar 25, 2007 | 11:41 AM
chevy94c's Avatar
The vigilante is a awesome tc. The cooler and drag radials are a good idea too.
Old Mar 26, 2007 | 02:44 AM
Z-RATED94's Avatar
Get the B+M trans cooler. The one that looks more like a small radiator. (A little help here guys on the part #.) You still use the cooler in the radiator first, and then through the B+M, and back to the trans. On a side note, your shifts will feel a bit soft with the new converter. Maybe give Frank (CPT) a call, and he can help you out with what needs to be done to the valvebody.
Old Mar 26, 2007 | 08:46 PM
hey01's Avatar
yea yea the B and M trans cooler that is what i meant, and yes i'll send the fluid thru both coolers (i saw a write up here on this before)
when its rebuilt im going to have the shifts made more exciting so I don't think that will be a problem. :-D
im just going to order my parts and when its out for the rebuild all this will be put back in.
drt
Sep 27, 2015 04:39 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
Aug 24, 2015 06:41 AM
POLOVETTE 94
Aug 21, 2015 07:11 PM
