M6 pedal wiring help
Old Mar 21, 2007 | 12:55 PM
PoorMan's Avatar
I need some advice on what goes where. Looking at this http://www.afrashteh.com/tranny_pics/T56.htm
it says to extend the yellow and brown wire and connect it to the clutch switch. I do not have a yellow and brown wire (94 model). I have a plug that has a pink and brown wire that was used on my brake pedal put I do not know what that is for. The other dual plug connector appears to be a direct swap over to my brake pedal though. Are their any switches unique to the m6 pedals? I bought m6 pedals with only the black clutch switch. Looking at a pic of a m6 pedal ***. with all the switches it looks like the white switch on the clutch is not on the A4 pedals. Any advice would be of great help. Thanks
JD
Old Mar 21, 2007 | 01:06 PM
Capn Pete's Avatar
The yellow & brown wires it says to extend to the clutch switch are 2 of the wires formerly connected at the automatic SHIFTER that are part of the ignition circuit. You must either A) splice them together at the shifter so your car will start, or B) extend them and connect them to the (black) clutch switch (so that you must push the clutch in order to start the car <safety feature>) .
Make sense?
... and the 2 plugs that previously plugged into the A4 brake pedal now plug into the M6 brake pedal ---> there's no change there.
Old Mar 21, 2007 | 09:34 PM
PoorMan's Avatar
Thank you for the reply. I understand.
JD
Old Apr 4, 2007 | 08:08 AM
PoorMan's Avatar
What about the switch for when the clutch is DISENGAGED? I guess I need to buy that. What wires do I use to hook it up?
Here is a pic of the switch I am talking about.
JD
Old Apr 4, 2007 | 02:55 PM
matLT1's Avatar
JD
That is the cruise control switch. You can either purchase what I believe is called a "y" harness to hook that up to the other cruise control or you can just purchuse a pigtail for that switch and wire it in series with the other.
Old Apr 4, 2007 | 04:42 PM
PoorMan's Avatar
Ok, thxs. I guess the other switch for cruise control you are talking about is the one on the brake? Who sells a y-harness? That would be nice to do it that way.
Old Apr 5, 2007 | 06:59 AM
Capn Pete's Avatar
Yeah, that switch is to dis-engage cruise when you press the clutch so the engine doesn't start revving up to the sky trying to maintain speed!
CARiD
Apr 8, 2015 08:08 AM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
BPS
9
Mar 5, 2015 10:51 PM
eazyZ
Mar 1, 2015 07:12 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
