any tips on keeping my 7.5 together at the track tonight?!?!
Old Mar 22, 2007 | 03:30 PM
Critter's Avatar
well thinking about getting to the track this weekend and was wondering if i could do anything to help keep it in 1 piece?
i think i have around 340-355 rwhp richmond gears and a ta cover. will be on street tires, but at a VERY prepped track. easy outta the hole or is there anything i can do to keep it alive?
Old Mar 22, 2007 | 08:14 PM
Capn Pete's Avatar
Street tires or DRs??
Either way, if you want to be easy on the diff., brake-stall it at the line ..... basically, hold the brakes with your left, and bring the revs up to ~1500 (seeing as you have a stall converter) so that way, the entire drivetrain is "pre-loaded" and there's no sudden shock on it ..... that's what kills 10-bolts is sudden shock/load. You should be fine to pretty much hammer it off the line (as long as you can get traction) and as long as you brake-stall it first .
Have fun and good luck!
Old Mar 22, 2007 | 09:01 PM
Critter's Avatar
turns out we are going tomorrow night but it will be on street tires.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
ModdedNerd
Dec 10, 2014 08:42 PM
