Ram Adjustable Clutch Master
just installed mine on my 99z
it's a stock unit with the adjustable heim joint attached to the shaft
comes with a pin for the hyd line, and the small 0-ring
now on mine i had to do some annoying surgery...the little ball socket on the heim joint was too wide to allow the retaining clip for the clutch pedal to slide on.
so i had to delicately touch it up with a hand held grinder...since its hardened steel...which isn't easy on a piece of metal that is the diameter of a nickel.
the thickness of the joint on the stocker was 13.25mm....the RAM unit was 13.75mm
i shaved it down to 13 to be cautious.
Ringmaster72
Mar 19, 2015 03:32 PM
