4L60E need help!!
Old Apr 6, 2007 | 08:04 PM
kline454's Avatar
4L60E need help!!
My car has taken out 3-4 clutch pack 3 times now, they have been lasting anywhere frond 50miles -9000miles, all other clutch look great, cant find anything wrong with any seals or *****,I was using the alto 9 disk, does anyone have any ideas?? as a side note im going to be puting the Z-pak in once I find the problem.
Old Apr 7, 2007 | 09:10 AM
12SCNDZ's Avatar
This is why we really don't advise anyone to rebuild their own 4L60E's. It gets time consuming and expensive...Especially if you start burning up $100 Z-Paks.
There are many many numerous things contributing to 3-4 life. First off, throw away that alto arrangement. What 2nd servo are you using? Are yiou using "load release" springs in the drum? Are you using a Trans Go shift kit? What are you drilling the hole in the plate to? Do you have a good air check? stator teflon rings sealing? Is the 3-4 piston sealing? Bad pump stator bushings? Still using the stock slide spring? What boost valve? Is the converter locking up?
If you're not real familiar with these transmissions, there's alot of things that can be overlooked.
Frank
CPT
Old Apr 8, 2007 | 10:41 AM
kline454's Avatar
ALL Air cheaks are good, all ***** and retainers are holding, its a jet servo, all drum springs are stock, .490 boost valve, all bushing look great, New tci 3500 lock up stall, transgo shift plate stock hole sizes,
Old Apr 8, 2007 | 11:02 AM
12SCNDZ's Avatar
Is the Jet billet, or just a "corvette" type? If you're using the 3-4 "load release" springs, you'll never keep 3-4's in it. Even with them, you should only see problems later than you are. You've got to be overlooking something.
You specified your converter. Are you sure it's locking up?
Frank
CPT
Old Apr 8, 2007 | 11:23 AM
kline454's Avatar
its a billet, are the load release springs the 5 sets the are on top of the 3-4 pistion fingers?
Old Apr 8, 2007 | 11:25 AM
kline454's Avatar
My car shifts at 6400 should i put a High Output Pump Slide Spring in?
Old Apr 8, 2007 | 11:29 AM
kline454's Avatar
overdrive servo is stock.
Old Apr 8, 2007 | 11:54 AM
kline454's Avatar
are the jet billet 4th servos any good?
Old Apr 8, 2007 | 02:20 PM
kline454's Avatar
CPT HELP!! thanks kyle
Old Apr 8, 2007 | 04:32 PM
12SCNDZ's Avatar
Yes, those are the springs. If you reuse them, you'll keep cooking 3-4's
Frank
CPT
Old Apr 8, 2007 | 04:33 PM
12SCNDZ's Avatar
Yes.
Frank
CPT
Old Apr 8, 2007 | 04:37 PM
12SCNDZ's Avatar
I'm not sure...I've never seen one. We use Fairbanks 2nd servios and Sonnax "Super Hold" 4th servos.
Frank
CPT
Old Apr 8, 2007 | 05:07 PM
kline454's Avatar
thanks,
Old Apr 9, 2007 | 10:13 AM
kline454's Avatar
Thanks CPT AND DANA @ PRO built,
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
