Is going to 3.73s from 3.23s worth it?
Just curious. I know going from 3.23s to 3.42s is a waste of time and money for minimal gains. And it's like going from 3.42s to 3.73s, very minimal or am I wrong? I just don't want to waste $500 on installed gears for only .2 tenths.
I had swapped 3.42s into my old a '91 Trans Am with stock 2.73s and it was a great mod. Especially since I got disc brakes in the process. Had aluminum drums stock.
personaly i would not waste the money...
i started with 2:73 and went to 3:73 and it was awesome... then the pinion gear shattered...
so then i bought a complete 3:42 and didn't notice any differance...
the next time i do gears i WILL be installing 3:23's...
reason 1 being i have more than enough to pull off a decent launch, reason 2 is that i noticed cars with lower gears seem to pull harder, and reason 3 is that they are stronger and i don't have all the money to throw into a 12 bolt...
Its a possibility, but hard to say. If you add a set of headers and some weight reduction into the mix then you should be able to snag some 12sec timeslips.
RUENUF
Mar 13, 2016 03:37 PM
Man up and get some 4.88's
