Oh man what did I do...
Old Mar 30, 2007 | 01:10 AM
stroked 383's Avatar
Ok my car is in my sig. I have the stock rear end w/ the 3.54 posi trac.
Tonite I was taking some drunk guys home and decided to [EDIT] w/ em and floor it in first gear. Well I rev'd it up fairly high and when I went to shift into second...it was all but impossible....
Now when I try to shift into any gear, its like I gotta slam it into gear. First and second gear are damn near impossible, and when I finally get it into gear the thing shimmies like crazy for about the first 1000 rpm....
Tomorrow I'll check the tranny fluid...but what did I do...I destroy my clutch, rear end, or something else? It was a stupid thing to do, and now I get to reap my jackass move. What could I have done to my car!?!?
Thanks for any responses!
Old Mar 30, 2007 | 02:12 AM
FeelTheSpeed's Avatar
Tranny maybe? Could be your clutch too, but I don't see how that could effect putting it into gear before you let the clutch out...unless you broke both tranny and clutch lol
Old Mar 30, 2007 | 03:06 AM
Mike96z's Avatar
How long ago did you change the clutch? Only thing you couldve done is, ****ed up the clutch. If its hard to get into gear when the car is not running with the pedal down then its the tranny, if its hard when running and you have a very hard pedal, most likely clutch.
Old Mar 30, 2007 | 03:14 AM
Heatmaker's Avatar
Advanced Member
DON'T FORCE YOUR CAR INTO GEAR!
pull that tranny off of there and see what's going on... other wise I guarantee you... You'll be fixing a tranny besides a possible busted clutch.
Old Mar 30, 2007 | 07:33 AM
If you can shift through the gears with the engine off, it's probably the clutch not disengaging.
Old Mar 30, 2007 | 10:13 AM
Alright on my lunch break I am going to go home and attempt to shift the gears while the car is off......Its not going to be driven until I figure out this problem...but I def did something. And I would've never forced it into gear but I had to get home! Needless to say I slept very little knowing I screwed up my ride.
Any other thoughts?
Old Mar 30, 2007 | 11:08 AM
Jared 3870's Avatar
Screwed the shifter forks or synchros?
Old Mar 30, 2007 | 11:12 AM
Any way you know of I can go about checking that?
Old Mar 30, 2007 | 12:35 PM
Heatmaker's Avatar
Advanced Member
When you try to shift gears with the car off, and it's hard as hell to move the stick in and out of certain gears. Since your gears are linked in pairs...
1-2, 3-4, 5-6, you can tell wich one is out of whack, you wont be able to tell the damage unless you pull the tranny apart though.
But usually you bend forks and jack up synchros when you force your car into gear, severly miss a gear... ETC. 1-2 gear shift is the most sensative and most common to break. Especially if you do what you were doing. Don't ask me how I know... but I will never forget that feeling when I pulled my tranny case off and say all the metal fragments laying about.
BTW what clutch are you running on that LS1 Slayer?
Old Mar 30, 2007 | 12:44 PM
Yeah I have called around and everyone is saying basically the same thing that I jacked up my synchros...looks like its going to be about $350-$500 to have a shop fix it for me... thank god its a 6 speed!
I have a Ram 400 clutch (rated to 400hp) but that bad boy slips if I rev the car out...its the torque not HP thats doing it....the clutch is the weakest point...minus my 10 bolt in my entire setup. Any recommendations on a new clutch while I have my tranny worked on?
Old Mar 30, 2007 | 04:48 PM
1. Wrong forum. I'll move it to "drivetrain".
2. Do not over ride the language filter.
Old Apr 2, 2007 | 02:25 PM
Ok when the car is off, I can easily run the car thru the gears. I can do this with or without the clutch pushed in. As soon as I turn on my car and attempt to put it into gear it just is all but impossible. I didn't try starting it in gear but that may be how I can get it outta the driveway..
I would think if it were just my clutch, that once I got it in gear it would've been like the car was in neutral...just like a bad clutch feels.
Needless to say I am basically positive that I screwed up my forks and synchros...but this is something I am not going to do myself. Anyone have any other thoughts about this?
Old Apr 2, 2007 | 03:15 PM
Can you start the engine with the car in gear and the clutch in? If the clutch is not disengaging, the car will try to move.
Old Apr 2, 2007 | 04:28 PM
Heatmaker's Avatar
Advanced Member
you honestly wont be able to diagnose the car, till you pull the tranny. I once had similar issues when my throwout bearing bent on the clutch fork. You'll know if it's the clutch or tranny once you get that T-56 off.
marlar98
Oct 21, 2015 02:02 PM
transamtom
Sep 16, 2002 05:47 AM
206 kaze
3rd Gen / L98 Engine Tech
Sep 8, 2002 11:37 PM
JasonD
Jul 29, 2002 01:46 PM
SpiXe
Jun 6, 2002 06:33 AM
